End G-Code Question ???
Hellbender
(@hellbender-2)
Is there anything you can add to the "End G-Code" box in the Printer settings tab that would automatically raise the print head to at least 120mm (or max height if tall print) over the height of the print when finished?
Thanks!
Posted : 25/11/2020 7:18 pm
RE: End G-Code Question ???
G1 Z120 would work, BUT If the Model is taller than 120,  this command may pull the extruder down into the model...
Posted : 25/11/2020 8:39 pm
Mostly.  Prusa printers already come with a line that does similar in the end gcode
{if layer_z < max_print_height}G1 Z{z_offset+min(layer_z+30, max_print_height)}{endif} ; Move print head up
That moves the head up 30mm but doesnt exceed the configured max height.  You could set a different value for 30 if you want to move it up higher.
Posted : 25/11/2020 8:59 pm
Hellbender
(@hellbender-2)
@neophyl
That would have to be done in printer firmware with Pronterface,  correct?  Not just in the slicer "End g-code"  box?
Posted : 26/11/2020 3:57 am
No that line as is is added into the printers end gcode section in Prusa slicer. If you want to see just use the wizard and add a mk3.
Posted : 26/11/2020 6:05 am
Hellbender
(@hellbender-2)
Thank you!
Posted : 27/11/2020 3:23 pm
Hellbender
(@hellbender-2)
@neophyl
Wow! I just changed the 30 to a 100, saved it,  and it did the trick!
It made a new "User Presets" with "copy" after the printer name.
Thanks again for the help!
Posted : 27/11/2020 4:35 pm
Yeah you can’t overwrite a system default, you always have to create a new one.  That’s true of any of the system profiles, even filament or print ones.
Glad it’s doing what you want.   The Prusa end code also has lines that moves the bed to the front to ‘present’ the finished print which is also handy to do at the end.
Posted : 27/11/2020 5:40 pm
