en g code problem
BblackmilkK
(@bblackmilkk)
en g code problem
When the process is finished, the z axis is up too much. How can I change it. Let's get up 20mm from the height of the model that ends.
orjinal gcode :
{if max_layer_z < max_print_height}G1 Z{z_offset+min(max_layer_z+2, max_print_height)} F600 ; Move print head up{endif}
G1 X5 Y{print_bed_max[1]*0.8} F{travel_speed*60} ; present print
{if max_layer_z < max_print_height-10}G1 Z{z_offset+min(max_layer_z+70, max_print_height-10)} F600 ; Move print head further up{endif}
{if max_layer_z < max_print_height*0.6}G1 Z{max_print_height*0.6} F600 ; Move print head further up{endif}
M140 S0 ; turn off heatbed
M104 S0 ; turn off temperature
M107 ; turn off fan
M84 X Y E ; disable motors
Best Answer by Neophyl:
You have 3 separate lines telling it to move up after printing.
this is saying move up 2mm if the extruder is at less than max print height.
Then you have
which is saying move up 70mm if less than max print height (or max print height).
Then you have {if max_layer_z < max_print_height*0.6}G1 Z{max_print_height*0.6} F600 ; Move print head further up{endif}
not 100% sure what thats doing  but its a move up.  I think its basically saying if the max layer is less than 60% of the max print height then move up to 60% of your maximum height.  So if you have a printer that can print for example 200mm high and it prints something say 1mm high then its going to move up to 120mm.  A bit extreme.  Personally I would remove or comment out that last one.
Why the hell do you have 3 lines basically doing the same thing ?
Napsal : 13/03/2022 5:13 pm
RE: en g code problem
Then you have
Napsal : 13/03/2022 5:22 pm
1 lidem se líbí
