Empty layer error when layer isn't empty
RayRay
(@rayray)
I'm only getting this error when I add supports, and it's indicating the Z layer where the first support material is extruded. As you can see in the second picture, it's definitely not an empty layer. If I remove the supports, the error goes away. Is there a fix for this?
This topic was modified 6 years ago by RayRay
Posted : 24/05/2020 5:14 am
Area51
(@area51)
RE: Empty layer error when layer isn't empty
Empty layers message is often triggered by a STL model with errors. Try running a repair on the model - if you are on Windows a right-click on the model and send it to Netfabb repair.
Posted : 24/05/2020 11:16 pm
RayRay
(@rayray)
Posted by: @area51
As I said in the top post, it's not an error in the STL, it's an error in the supports. If I turn off support generation, the error message goes away. At any rate, I already tried Netfabb repair after adding the supports and I still got the error.
Posted : 25/05/2020 12:59 am
I tried the Universal Einsy Box, in my Prusa Slicer setup.
I didn't get the error message
So I added Mouse Ears,
I have added the  Zipped  .3mf file below
Attachment removed
Posted : 25/05/2020 10:49 am
Area51
(@area51)
@tigersnake
Maybe saving the project to .3mf file, zipping it and upload to the forum will make it possible to find the problem with support.
Posted : 25/05/2020 11:22 am
