[Docker Container] Prusaslicer noVNC (Prusaslicer in your browser)
Page 2 / 2
Morcegolas
(@morcegolas)
@mkurz
Hello, can you share you steps to get it working please? I’m running DSM 7.2 with docker and portainer but I don’t understand too much to this by my own, I’m also using port 8080 to qbittorrent so I would have to change the port.
This post was modified 1 year ago by Morcegolas
Posted : 19/12/2023 11:52 am
Morcegolas
(@morcegolas)
RE: [Docker Container] Prusaslicer noVNC (Prusaslicer in your browser)
I managed to install it but I cannot mount /prints/ folder.
Posted : 22/12/2023 1:28 am
mkurz
(@mkurz)
when you run the image in the container manager you can add paths. You need to add them there.
Add a local source on your NAS for the configs mount and one for your prints.
You can also edit your ports there. IIRC i just followed the steps in the guide on the GitHub.
This post was modified 1 year ago by mkurz
Posted : 22/12/2023 7:45 am
Morcegolas
(@morcegolas)
Posted by: @mkurz
Hi. Thanks for the reply. It indeed works. I‘m currently running it on my DS423+ depending on the model its a bit slow in the preview but thats totaly fine for my needs.
This NAS has an Intel Celeron J4125 and i maxed out the RAM to 18GB.
thank you
Could you share your docker compose file so I could try something similar?
Thanks.
Posted : 22/12/2023 11:17 am
Aroon
(@aroon)
Hey,
i tried to install on Container Manager on a Synology DS1817+ running DSM7.2.
I tried with following yaml:
version: "2.1"
services:
  prusaslicer-novnc:
    image: mikeah/prusaslicer-novnc
    container_name: prusaslicer-novnc
    environment:
      - SSL_CERT_FILE=/etc/ssl/certs/ca-certificates.crt
      - NVIDIA_VISIBLE_DEVICES=0
      - NVIDIA_DRIVER_CAPABILITIES=all
      - DISPLAY=:0
      - VGL_DISPLAY=egl # needed to run without X server
      - SUPD_LOGLEVEL=TRACE
      - ENABLEHWGPU=true
      - VNC_RESOLUTION=1920x1080
      - NOVNC_PORT=5910
      #- VNC_PORT=5900
    volumes:
      - /volume1/public/3DPrint:/prints/
      - /volume1/docker/prusaslicer:/configs/
    restart: unless-stopped
But i cannot reach the WEB-UI. Any ideas?
Some parts of the log:
(prusa-slicer:20): Gtk-CRITICAL **: 20:56:23.600: gtk_cell_layout_get_cells: assertion 'GTK_IS_CELL_LAYOUT (cell_layout)' failed
(prusa-slicer:20): GLib-GObject-WARNING **: 20:56:23.600: invalid cast from 'wxPizza' to 'GtkCellLayout'
xauth:  file /home/slic3r/.Xauthority does not exist
proxying from :5910 to localhost:5900
DEBG 'novnc' stdout output:
No SSL/TLS support (no cert file)
Web server. Web root: /usr/share/novnc
Listen on :5910
WebSocket server settings:
Log file is /home/slic3r/.vnc/29034af21852:0.log
Starting applications specified in /opt/TurboVNC/bin/xstartup.turbovnc
Desktop 'TurboVNC: 29034af21852:0 ()' started on display 29034af21852:0
DEBG 'vnc' stdout output:
INFO success: prusaslicer entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
INFO success: vnc entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
INFO success: novnc entered RUNNING state, process has stayed up for > than 1 seconds (startsecs)
Posted : 30/01/2025 9:08 pm
_KaszpiR_
(@_kaszpir_)
You probably need to add section 'port's in the yaml to expose the service with a mapping of host port to container port.
Posted : 31/01/2025 9:34 am
Aroon
(@aroon)
Posted by: @_kaszpir_
Correct! I added following line and can now access the web interface.
ports:
- 5910:5910
- 5900:5900
Now i can see the slicer, but it's flickering all the time and it is not useable.
Is a DS1817+ not good enough for running this?
Posted : 31/01/2025 2:05 pm
_KaszpiR_
(@_kaszpir_)
I don't know any Synology device.and it's performance,.though some things o consider:
1. Remove SUPD_LOGLEVEL=TRACE from the options, because this is mainly for debugging
2. Try without ENABLEHWGPU=true or lower the resolution
Posted : 03/02/2025 7:27 am
Page 2 / 2
