Display Filename
SnowEagle
(@snoweagle)
Display Filename
I changed my Printer Settings Start G-Code using M117 to provide me with various prompts an info during setup. But when the print starts I want to see the filename that is printing. How or what code do I use to complete this task?
Napsal : 08/08/2021 6:50 pm
M117 [input_filename_base] perhaps?
Have you tried simply adding one more M117 command with the filename after all your setup prompts? Something like:
Also, if you are using OctoPrint, there are other alternatives.
Napsal : 08/08/2021 7:01 pm
SnowEagle
(@snoweagle)
Thanks "bobstro"
That works perfectly. I'm using it on your g-code startup routine.
Napsal : 09/08/2021 6:01 pm
1 lidem se líbí
