					                		Different Material for Support Interface - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/different-material-for-support-interface/</link>
                <lastBuildDate>Mon, 13 Apr 2026 10:20:29 +0000</lastBuildDate>
                        <title>RE: Different Material for Support Interface</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/different-material-for-support-interface/#post-780026</link>
                        <pubDate>Wed, 28 Jan 2026 13:10:25 +0000</pubDate>
                        <description><![CDATA[Use the Configuration Assistant to install the Mk4S MMU3 profile for your nozzle size. To slice, select the Soluble Interface print profile. I found Soluble Interface works okay if you have ...]]></description>
                        <content:encoded><![CDATA[<p>Use the Configuration Assistant to install the Mk4S MMU3 profile for your nozzle size. To slice, select the Soluble Interface print profile. </p><p>I found Soluble Interface works okay if you have pretty horizontal contact surfaces. For angled surfaces, the interface material usually slides off the supports</p><p> </p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/different-material-for-support-interface/#post-780026</guid>
                        <title>Different Material for Support Interface</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/different-material-for-support-interface/#post-779978</link>
                        <pubDate>Wed, 28 Jan 2026 02:05:41 +0000</pubDate>
                        <description><![CDATA[I have a MK4 / MMU3. I’d like to print the support interface layer from PLA if the main object is PETG (or vice versa). This is to facilitate a clean and easy breakaway of the support materi...]]></description>
                        <content:encoded><![CDATA[<p>I have a MK4 / MMU3. I’d like to print the support interface layer from PLA if the main object is PETG (or vice versa). This is to facilitate a clean and easy breakaway of the support material from the main object.</p><p>How do I do this using the Prusa slicer?</p><p>Thanks,</p><p>Tom</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Tom De Winter</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/different-material-for-support-interface/#post-779978</guid>
