Different line width for height modifier
Dr.Print
(@dr-print)
I have a MK3S+ with MMU2S with a standard nozzle of 0.4 mm, the PrusaSlicer is set to Expert mode. I want to reduce the line width for some specific layers.
I have an object with the following structure:
  1. from 0 mm to 0.6 mm a transparent layer
  2. from 0.8 mm to 1.2 mm some filigree structures, which are visible through the transparent layer
  3. from 1.4 mm to the end is the rest of the object
Is it possible to change the line width just for the range from 0.8 mm to 1.2 mm? I created a height modifier for this range, but cannot find the settings for the line width. For the whole print they are under "Print Settings - Advanced - Extrusion width". But I do not want to print the whole object with a reduced line width, just the mentioned layers.
Respondido : 01/12/2024 1:53 pm
Dr.Print
(@dr-print)
RE: Different line width for height modifier
Okay, just found it. "Add settings - Extrusion width" - that simple.  No idea why I clicked about 10 minutes through the settings, when it was all the time right in front of my eyes......
Respondido : 01/12/2024 1:59 pm
1 les gusta
