Different line width for height modifier
I have a MK3S+ with MMU2S with a standard nozzle of 0.4 mm, the PrusaSlicer is set to Expert mode. I want to reduce the line width for some specific layers.
I have an object with the following structure:
- from 0 mm to 0.6 mm a transparent layer
- from 0.8 mm to 1.2 mm some filigree structures, which are visible through the transparent layer
- from 1.4 mm to the end is the rest of the object
Is it possible to change the line width just for the range from 0.8 mm to 1.2 mm? I created a height modifier for this range, but cannot find the settings for the line width. For the whole print they are under "Print Settings - Advanced - Extrusion width". But I do not want to print the whole object with a reduced line width, just the mentioned layers.
Napsal : 01/12/2024 1:53 pm
Topic starter
answered:
RE: Different line width for height modifier
Okay, just found it. "Add settings - Extrusion width" - that simple. No idea why I clicked about 10 minutes through the settings, when it was all the time right in front of my eyes......
Napsal : 01/12/2024 1:59 pm
1 lidem se líbí
