Cut tool - Connector alignment?
Roger
(@roger-10)
The Cut tool has a pretty cool Connectors feature that I'm using in a current project. But I don't see any way to precisely place the connectors. It puts a colored area on the cut face but there are no alignment crosshairs, measurements or anything. For a specific reason I'd like to place the connector in the exact center of the (circular) face, which would allow me to rotate the pair of parts. As it is, the peg placement can be off just a bit, so the parts don't remain aligned when rotated. Is there any way to place the connectors automatically or more exactly?
Postato : 20/02/2025 5:03 am
RE: Cut tool - Connector alignment?
in a case like this, I would model the cut, peg and hole in my 3d design program before adding the files to Prusa slicer
have you considered making this use case suggestion to the Prusa Dev's in the Prusa Slicer Git Hub area. Check yo see it a request has already been made, if it has, add your name as an interested party, if yours is a new request, add as much supporting information, as possible.
Postato : 20/02/2025 10:18 am
