Custom Tool Change GCode HELP
[Resuelto] Custom Tool Change GCode HELP
alecksonj001
(@alecksonj001)
Hi
I have a custom Ender 3 with a Y Splitter for dual extrusion. I'd love to be able to write custom gcode for it, but I can't for the life of me find what the gcode is for *next tool*. Cura has separate start and end custom gcode scripts for each extruder, so you obviously can edit those individually. In lieu of that, I need to be able to write the code using things like "current tool" "inactive tool" etc.
Thanks!
Best Answer by Neophyl:
Only information I'm familiar with is this https://github.com/prusa3d/PrusaSlicer/wiki/Slic3r-placeholders-(a-copy-of-the-mauk.cc-page)
Beyond that I think you will need to ask on the prusa Slicer github page.
Respondido : 09/06/2020 1:48 am
Area51
(@area51)
Miembro
RE: Custom Tool Change GCode HELP
In expert mode under Printer Settings it is possible to write g-code for tool change.
Respondido : 09/06/2020 10:28 am
Respondido : 09/06/2020 10:52 am
1 les gusta
alecksonj001
(@alecksonj001)
@neophyl
That had what I needed. Thanks!
Respondido : 09/06/2020 6:32 pm
deonholt
(@deonholt)
Posted by: @alecksonj001
Hi
Thanks!
Hi.
I started using PrusaSlicer about 3 hours ago. I usually used Cura. I have an Ender 5 also with Y-splitter & dual extruders.
I'm battling in Cura to get a dual colour square to have an acceptable look. It looks terrible, to say the least.
So going from Cure to Prusa, is a completely different ball game ... something I am busy discovering.
Did you manage to get your machine with the Y-splitter to work? I will really appreciate it if you can help me with your/sample gcode to get my printer going again. I tried but it only did a small print of something that looks like a very narrow strip and then said it is finish with the print.
Thank you so long. Will really appreciate your help.
Respondido : 28/11/2020 7:28 pm
MagicMitch
(@magicmitch)
@alecksonj001
can you post your script I have a similar issue and your solution could help me
THANX
MITCH
If I had a son he would be a son of a Mitch
Respondido : 09/02/2021 6:22 pm
