Custom Start G-Code
INVESTEGATE
(@investegate)
Custom Start G-Code
Hey, i want to do a special Start G-Code for my Prusa Mk3s. I want to do something like this:
M104 S{[first_layer_temperature] - 50} ; custom hot end temp minus 50 degrees
But it didn´t work like this. What did i make wrong?
Best Answer by karl-herbert:
the syntax is as follows:
M104 S{first_layer_temperature[initial_tool]+10}
see here: https://help.prusa3d.com/article/macros_1775
wbr,
Karl
Posted : 09/06/2022 5:56 pm
towlerg
(@towlerg)
Not sure what the problem is but
M104 S[first_layer_temperature]
is legal. Maybe the second set of brackets? Or maybe round brackets, Slic3r (from which Prusaslicer was forked) variable syntax is all over the place.
This post was modified 4 years ago by towlerg
Posted : 09/06/2022 6:35 pm
RE: Custom Start G-Code
wbr,
Karl
Posted : 09/06/2022 8:56 pm
towlerg
(@towlerg)
@karl  Thanks for the info and particularly the link. BTW it seems you can reduce initial_tool to 0.
Posted : 10/06/2022 9:42 am
I think thats because Extruder 1 = Tool 0, extruder 2 = tool 1.  Like a lot of code tables start from index 0 and not index 1.
Posted : 10/06/2022 10:40 am
INVESTEGATE
(@investegate)
Thanks you very much! With your help, i could fix my problem 😀 The Prusa Community is really the best i know!
This g-code works fine:
M104 S{first_layer_temperature[0] - 50} ; custom hot end temp minus 50 degrees
Posted : 10/06/2022 11:42 am
list of PS placeholders: https://help.prusa3d.com/article/list-of-placeholders_205643
wbr,
Karl
Posted : 10/06/2022 1:26 pm
