Custom GCode help
Part of my Printer custom GCode is
M104 S{first_layer_temperature[0]*0.9} ; set extruder temp to 90%\n
M140 S[first_layer_bed_temperature] ; set bed temp\n
M190 S[first_layer_bed_temperature] ; wait for bed temp\n
M104 S[first_layer_temperature] ; set real extruder temp\n
M109 S[first_layer_temperature] ; wait for extruder temp\n
I did this because I didn't want the nozzle sitting a high temp waiting for bed.
Which works quite well except where I immediately restart. Then the nozzle temp is set to the 90% value even thought it's already above that and thus cools while bed heats. I'd like to add a condition to the effect that if nozzle temp greater than "{first_layer_temperature[0]*0.9}" then nozzle temp = "[first_layer_temperature]" else nozzle temp = "{first_layer_temperature[0]*0.9}". Any help appreciated.
BTW why the syntax is different is because it's cobbled together from posted scripts.
RE: Custom GCode help
You can use the max function to choose the larger of two values.
M140 S{max(first_layer__temperature[0],160)}
Unfortunately, that won't work. All conditional code is evaluated in the slicer, not the printer. On the Mk3, you can not evaluate conditions in gcode.
There is the R option to M140 that should continue if the temp is higher, but I recall it doesn't work. It always waits for the nozzle to hit the specified temperature.
As Bob says the correct Gcode command is the M140 R{first_layer_temperature[0]*0.9} but R was not implemented on the Prusa MK3.
If however you have a different printer then it may be implemented in its firmware. Wont hurt to try it and see.
Ah, good point. I forgot @towlerg has a Sovol. If you've loaded Marlin 2, there's a very good chance the expanded command options work.
Thanks guys I'll give it a go.
Of course I should have realized, the slicer can't possible know about realtime data. I think I'm going to have to migrate this code to OctoPrint.
