Create only 1 outer permiter
eslavko
(@eslavko)
Miembro
I wish to print compillant mechanism and have trouble doing that. In the photo is section where problem is. The thickness of wall is exact nozzle size. I did try many of settings but all fail. What I expect is to get constant extrusion speed for outer perimeter and inside perimeter  to be ended or folded like the second perimeter is. In image bellow the Arachne perimeter generator is used which slow down extrusion in that radius and try to blend outer and inner perimeter as one extrusion but that make bad wall for compilant mechanism. So how to attack this problem. (I use 0.8mm nozzle and need consistent 0.8mm wall without joints in this area. 1.6mm wall is to thick, 0.4mm nozzle is to slow.)
Respondido : 23/07/2025 11:52 am
