Could I have the modifier number of perimiters define the intersection between the main object and modifier.
Wetdesign
(@wetdesign)
I have cut an object into two in Prusa slicer, and I want to print them so that the cut areas have fewer perimiters than the objects, or no perimiters at all. When printing a big part with flex it has to be cut. If the main part(s) needs say 3 perimiters, then when the two parts are glued together they would have 3+3 perimiters in the joined area. I want to have 0, or at most 1 perimiter on each side. One on the modifier side, one on the main non-modified object.
Any suggestions how to accomplish that? If they are joined before printing there would not be a perimiter between the objects, but then it would be too big again, for the printer.
Este debate ha sido modificado el hace 2 years por Wetdesign
Respondido : 03/11/2023 3:18 pm
