Correct Workflow to add nozzle variants
sticilface
(@sticilface)
I've got a core one.  Two nozzles the 0.4mm HF nozzle that comes with it, plus an obxidian nozzle.
I seem to have 2 physical profiles one for each nozzle from when i did this ages ago, but im now trying to use the new 2.9.3 profiles to get the VFA artifact removal.
If I go to add printer profiles, I get core one with 0.4mm HF and non-HF variants.  The HF variant has the new 'BALANCED' profile whereas the non-HF does not.  There is also no option for the obxidian nozzle there any more.
This all seems really clunky, every time i want to update the printer profile I have to add, then apply all my changes.. custom wipe g-code, the api key and IP for the physical printer... and for both nozzles...
My question is.  Am I doing this all wrong, or is there a different way?   also whats the best way to add this custom obxidian nozzle that doesn't appear to be in the profiles.
Opublikowany : 20/09/2025 10:00 am
