Correct Workflow to add nozzle variants
I've got a core one. Two nozzles the 0.4mm HF nozzle that comes with it, plus an obxidian nozzle.
I seem to have 2 physical profiles one for each nozzle from when i did this ages ago, but im now trying to use the new 2.9.3 profiles to get the VFA artifact removal.
If I go to add printer profiles, I get core one with 0.4mm HF and non-HF variants. The HF variant has the new 'BALANCED' profile whereas the non-HF does not. There is also no option for the obxidian nozzle there any more.
This all seems really clunky, every time i want to update the printer profile I have to add, then apply all my changes.. custom wipe g-code, the api key and IP for the physical printer... and for both nozzles...
My question is. Am I doing this all wrong, or is there a different way? also whats the best way to add this custom obxidian nozzle that doesn't appear to be in the profiles.
