Command line scale pushes model through floor
Hey everyone,
Wondering if anyone knows the solution to this. When Slicing using the command line with the option "--scale N" the model seems to get scaled from its center which causes the model to go through the floor, the resulting gcode I get as a result is missing the bottom part of the model (the more its scaled the more goes missing under the floor height) .
Does any know a way to make sure the model is moved back to the surface when scaling?
cheers.
Questa discussione è stata modificata 5 years fa da sot
Postato : 14/01/2021 12:25 am
Topic starter
answered:
RE: Command line scale pushes model through floor
All good I worked it out... I had "--center X,Y" before the scale... seems like the order of options matters and putting the center after the scale puts it back on the build plate
Postato : 14/01/2021 4:28 am
1 persone hanno apprezzato
