"Combing Mode - Not in Skin" on PrusaSlicer?
glauco.ramos
(@glauco-ramos)
Hi! 😀
I selected the option "avoid crossing perimeters" to avoid the formation of strings on the outside of my model. However, I had a problem with this setting, because the path that the nozzle took, following the outer wall, left a terrible final aspect. In Cura I was able to get around this problem by choosing the option "combing mode - not in skin". Would anyone have a suggestion of what to use on PS to solve this problem? Thanks!
This topic was modified 5 years temu by glauco.ramos
Opublikowany : 26/03/2021 9:37 pm
RE: "Combing Mode - Not in Skin" on PrusaSlicer?
You can try adjusting Max detour length to avoid those length detours. If you are experiencing stringing, probably better to focus on reducing that instead of working around the issue.
Opublikowany : 26/03/2021 9:58 pm
