Coloring tool
It would be great to be able to upload a 2D image and convert that into 2-5 colors based on whatever you choose. Then take that image and apply it to the 3D object in slicer. It could be as simple as applying whatever color is above through the entire vertical plane, only applying through a set depth once it hits an object, or as complex as wrapping around the object. That would significantly increase users’ willingness and ability to use color in their prints.
Opublikowany : 07/05/2025 1:10 am
That's a job for CAD, not the slicer. Your CAD package probably lists it under texturing.
Opublikowany : 07/05/2025 8:12 pm
