Chromebook install error - cannot execute binary file: Exec format error
Mark Gebert
(@mark-gebert)
I get an error after trying to execute the Prusa Slicer appimage file.  Any ideas on what is going wrong?
mgebert@penguin:~$ chmod a+x PrusaSlicer.AppImage
mgebert@penguin:~$ ./PrusaSlicer.AppImage
-bash: ./PrusaSlicer.AppImage: cannot execute binary file: Exec format error
mgebert@penguin:~$
Posted : 14/10/2022 10:06 pm
jsw
 jsw
(@jsw)
RE: Chromebook install error - cannot execute binary file: Exec format error
My first guess is that you have the incorrect image for your processor.
IIAC, Chromebooks can use either the ARM type processors, or the Intel-derived processors.  You need the correct appimage for the processor.
It could also be a corrupt image file.
Posted : 15/10/2022 2:00 am
JimB
 JimB
(@jimb)
I tried it on my chromebook.  Running uname -m showed the architecture to be "aarch64".  So I downloaded the appimage with aarch64 in the name.  The GTK2 one did not work for me (missing library), but the GTK3 one did run.
Posted : 15/10/2022 2:05 pm
jsw
 jsw
(@jsw)
That is definitely an ARM type processor, but Chromebooks can be different depending on type.
Posted by: @jimb
Posted : 15/10/2022 8:19 pm
Mark Gebert
(@mark-gebert)
Changing image files got the slicer working.  The file system cannot directly write to the SD Card and I noticed some file access errors on Linux command line editor so I am may try the third image file in the build.  But all the non-file system features of the Prusa Slicer work without any issues.
Posted by: @jsw
Posted : 06/12/2022 7:53 am
