Changing Nozzle Temperature During Print
I'm using Prusa Slicer 2.3.0 and printing with a Prusa Mini (Bondtech Extruder and Heatbreak)
When slicing a Temperature Tower to test new filaments, can I insert temperature changes at set levels, in the same way that I am able to insert filament changes via the vertical slider on the right side of the screen? I've done it manually before, but that means I need to wait next to the printer for most of the printing time.
RE: Changing Nozzle Temperature During Print
Sure you can. One example: https://www.prusaprinters.org/prints/39810-improved-all-in-one-temperature-and-bridging-tower. Check out the 3mf files to see how the change filament gcode is done.
Alternatively instead of using the layer slider to insert a colour change you can right click the plus and choose insert custom gcode. You can then enter whatever gcode you want and it will be inserted at that layer. So just add what temp you want.
M104 S
The Filament Whisperer
What a helpful community, and thanks for the replies, which have exactly answered my question. 👍 I'll now make up a .gcode file of my temperature tower and save it for testing some new filaments I'm keen to try.
