					                		Change solid infill settings to use top fill pattern - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/change-solid-infill-settings-to-use-top-fill-pattern/</link>
                <lastBuildDate>Sun, 19 Apr 2026 15:08:14 +0000</lastBuildDate>
                        <title>RE: Change solid infill settings to use top fill pattern</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/change-solid-infill-settings-to-use-top-fill-pattern/#post-756198</link>
                        <pubDate>Wed, 02 Jul 2025 20:09:27 +0000</pubDate>
                        <description><![CDATA[Short answer is you can&#039;t.  The top infill pattern is only applied to the very top layer, always has been.   On the solid infill, well short answer is also you cant.  Longer answer is you so...]]></description>
                        <content:encoded><![CDATA[<p>Short answer is you can't.  The top infill pattern is only applied to the very top layer, always has been.  </p><p> </p><p>On the solid infill, well short answer is also you cant.  Longer answer is you sort of can but it requires use of modifiers.</p><p>The solid infill pattern used to just be regular cross hatched pattern until a few versions ago.  Then they changed it to its current behaviour.  Its to reduce violent shaking on small areas amongst other things.</p><p>There have been several posts here and on the github about this.   For example https://github.com/prusa3d/PrusaSlicer/issues/10573  </p><p>For the infill with modifiers you can read https://github.com/prusa3d/PrusaSlicer/issues/13563  </p><p>Same with requests to change the function - https://github.com/prusa3d/PrusaSlicer/issues/2147 (that one from 2019)</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/change-solid-infill-settings-to-use-top-fill-pattern/#post-756198</guid>
                        <title>Change solid infill settings to use top fill pattern</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/change-solid-infill-settings-to-use-top-fill-pattern/#post-756137</link>
                        <pubDate>Wed, 02 Jul 2025 04:26:28 +0000</pubDate>
                        <description><![CDATA[I&#039;m having issues with my top layers:SOLID INFILL (adjacent to topmost layer)TOP INFILLThe concentric pattern in the solid infill seems to only happen on thin elements. The issue is that thi...]]></description>
                        <content:encoded><![CDATA[<p>I'm having issues with my top layers:</p><p>SOLID INFILL (adjacent to topmost layer)</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/07/5ffbb63f-screenshot-2025-07-02-001332.png"><img class="alignnone size-medium wp-image-178261" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/07/5ffbb63f-screenshot-2025-07-02-001332-600x351.png" alt="" width="600" height="351" /></a></p><p>TOP INFILL</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/07/924ba52b-screenshot-2025-07-02-001424.png"><img class="alignnone size-medium wp-image-178262" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/07/924ba52b-screenshot-2025-07-02-001424-600x409.png" alt="" width="600" height="409" /></a></p><p>The concentric pattern in the solid infill seems to only happen on thin elements. The issue is that this pattern is causing overextusion in the centre of the pattern. I'd like to fix the problem:</p><p>1) by minimizing the overextrusion caused by the concentric pattern or<br />2) by applying the top infill pattern to the solid infill instead. <br /><br />Any help is appreciated!</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Ence</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/change-solid-infill-settings-to-use-top-fill-pattern/#post-756137</guid>
