change Layerheight exact from 0.2 to 0.1mm at a specific Layerheight.
I want to print the first Layers 0.1mm up to 3.8mm then change the layerheight to 0.2 until the print reaches 110mm and then change the layerheight again to 0.1 mm. Is that possible to configure in / with PrusaSlicer?
Thx for help - Carsten
This topic was modified 6 years temu 3 times by PPRRUUSSAA
Opublikowany : 24/01/2020 2:06 pm
RE: change Layerheight exact from 0.2 to 0.1mm at a specific Layerheight.
Right-click on your object and choose "Height range Modifier". Enter start and end height and the desired layer height. Click on the "+" to add more steps.
Opublikowany : 24/01/2020 3:12 pm
Topic starter
answered:
That was easy. Thanks, you made my day. -Carsten
Opublikowany : 24/01/2020 3:41 pm
