Change default G-code
NielsE
(@nielse)
I have added a nozzle wipe to my Core One that necessitates a change in the G-code. Is there a way to change the default code permanently so I do not have to make the change for each print or to have multiple presets (for example a preset for each nozzle etc) ?
Thanks in advance.
Posted : 29/06/2025 9:59 am
RE: Change default G-code
You update your printer profile with the nozzle wipe (which it sounds like you already have done ?) then you save the profile as a new custom one.  As you cant update a system pre-set.  You then select that new printer profile to use for slicing.  Every print job that uses that profile will then contain your updated gcode.
Unfortunately there's no global way to update everything so you will need to save your own custom profiles for all your nozzle sizes.  You will need to make the change for each one and then save it.  Once done though its done.  Just have to remember to select the correct profile.
Posted : 29/06/2025 10:12 am
3 people liked
