Can't make changes to support material settings in PrusaSlicer 2.2
Buck
 Buck
(@buck)
PS is set to Expert mode.  Under Print Settings, support materials options are grayed out and I cannot change them. What did I miss?
Napsal : 06/06/2020 3:07 pm
Buck
 Buck
(@buck)
RE: Can't make changes to support material settings in PrusaSlicer 2.2
Never mind. Realized you can't change these settings until you enable supports on the plater.
Napsal : 06/06/2020 3:10 pm
4 lidem se líbí
DragonDon
(@dragondon)
This will sounds weird but thank you for making that mistake.  This post was a top result because I found the exact same issue!
Napsal : 18/01/2022 11:53 pm
Lewis DAC
(@lewis-dac)
5 years later and helped me out, thought i was losing my mind
Napsal : 23/01/2025 4:35 pm
