[Solved] Cannot Remove Perimeters
aaron bastian
(@aaron-bastian)
Hello,
I have a part which I am trying to print the infill only + one bottom layer. I set the number of perimeters and top layers to 0, but it still generates 1 external perimeter. You can see all of the other options I tried to disable which I thought might be causing this.
Please let me know if anyone can replicate on their end. I am at my work where I have to use Qidi-slicer because I have a Qidi printer. This is just a wrap of Prusa slicer though and I have never noticed any differences from prusa slicer.
Thanks!
Best Answer by aaron bastian:
Found out that I could fix this by changing the perimeter generator back to classic, but I feel like you should be able to do this regardless and I swear that I had done this before without needing to mess with that setting.
Napsal : 23/07/2024 10:23 pm
aaron bastian
(@aaron-bastian)
RE: Cannot Remove Perimeters
Napsal : 23/07/2024 10:33 pm
BaconFase
(@baconfase)
I think it's something on your/Qidi's end since it works as you'd expect on PS2.8.0 with arachne. But I don't have/use Qidi anything so I don't really have any further advice.
Napsal : 26/07/2024 3:43 am
