Cannot install 2.3.0 final, says I don't have internet
[Risolto] Cannot install 2.3.0 final, says I don't have internet
Pagina 1 / 2
WerkRaum
(@werkraum)
Hi there, I am getting an error installing 2.3.0 which I just downloaded. It says that an internet connection is required - which I have. IT then stops the installation.
How can I debug this? Is this a temporary issue where some server is down that the software tries to connect to? Or can you tell me how the software checks if it's connected to the internet so I can see what the issue is?
thanks
Best Answer by Dan:
Got it. It was because I had downloaded the "Stand Alone" installer file which doesn't work. The simpler Windows version worked without a hitch.
Postato : 12/01/2021 2:26 am
VisualFeast
(@visualfeast)
RE: Cannot install 2.3.0 final, says I don't have internet
I have the same issue. No proxy or VPN here.
Postato : 12/01/2021 5:53 am
Maub
 Maub
(@maub)
Same here. I'm using Win 10 Pro 20H2
Postato : 12/01/2021 8:34 am
Utenti
It might help if you post which OS and a little more information.
Postato : 12/01/2021 11:25 am
HBRSC
(@hbrsc)
Same problem here, using Win10
Stefan
Questo post è stato modificato 5 years fa da HBRSC
Postato : 12/01/2021 11:38 am
1 persone hanno apprezzato
WerkRaum
(@werkraum)
Sorry about forgetting this. I am running windows 10.
Apart from that, not sure what to write. My system is working perfectly and all other software can connect normally.
Here's a screenshot.
Questo post è stato modificato 5 years fa 2 tempo da WerkRaum
Postato : 12/01/2021 12:10 pm
AlsInvent
(@alsinvent)
Same here. Win 10 Pro Version 1909
Postato : 12/01/2021 2:37 pm
I just installed the 2.3.0 without errors on the following system:
MS W 10 Pro, 10.0.19042 build 19042
It might be possible that your firewall is blocking something? Possibly install as admin?
Postato : 12/01/2021 2:49 pm
Dan
 Dan
(@dan-29)
Has there been a fix recommended for this yet? I'm having the same issue.
Postato : 12/01/2021 2:54 pm
Utenti
@karl-herbert
I was also able to install it on my Windoze machine.  Mac and Linux also worked without a hitch.
Postato : 12/01/2021 2:56 pm
HBRSC
(@hbrsc)
Posted by: @karl-herbert
As i work in a large company, it is not an option for me to change anything on the side of the firewall.
I run the installation with admin rights, Slicer 2.2.0 and the required drivers was no problem.
Stefan
Postato : 12/01/2021 3:35 pm
Pyroschnüffler
(@pyroschnuffler)
Hello i wrote in German forum.
I have the same isue. He asks for internet, and i am online.
I have it, Kaspersky has blocked.
Deaktivate it and works.
Questo post è stato modificato 5 years fa da Pyroschnüffler
Postato : 12/01/2021 4:24 pm
Maub
 Maub
(@maub)
As mentioned in my previous post, in my case installation failed on a Windows 10 20H2 system (an Asus Zenbook Pro UX58). Today I tried again on a Lenovo ThinkPad W530 (with Windows 2004) and the installation completed without problems.
I then tried to temporarily disable Windows Defender Firewall on the Asus laptop (it was enabled on the ThinkPad) and installation was successful.
Postato : 12/01/2021 5:53 pm
Dan
 Dan
(@dan-29)
@maub
Ok let me give that a shot. I tried it once with security off, but I'll see maybe if I missed something the first time. Thanks for the response.
Postato : 12/01/2021 6:25 pm
Dan
 Dan
(@dan-29)
I confirmed all firewalls and virus software was turned off. Still gives the same message unfortunately.
Postato : 12/01/2021 6:31 pm
Fun King 3D
(@fun-king-3d)
Had the same issue. Disabled Avast antivirus (by suggestion of an awesome person) and it installed fine.
Postato : 12/01/2021 9:17 pm
WerkRaum
(@werkraum)
I have webroot, disabling it does not solve the problem.
Postato : 13/01/2021 2:06 am
Dan
 Dan
(@dan-29)
Postato : 13/01/2021 2:07 am
WerkRaum
(@werkraum)
Hey all, can confirm that the stand-alone is broken, the normal version works fine.
Postato : 13/01/2021 8:16 am
Tim Sherrill
(@tim-sherrill)
@dan-29
What 'simpler version' do you mean? I'm getting the same problem with the standalone install.
Postato : 17/01/2021 6:20 pm
Pagina 1 / 2
