Cannot change Z of modifier block or cylinder
phiba
(@phiba)
Membre
In PrusaSlicer 2.8.1, I cannot change the Z position of a modifier block or cylinder. If I use the position control to raise the modifier, it moves up, then drops back down to the plate surface. And if I enter a different Z value in the Object manipulation box, it returns to the original value. This happens whether or not I have imported a STL file. The X and Y axis controls work as expected. What am I doing wrong? I do not recall having this problem before.
Publié : 28/11/2024 2:50 am
phiba
(@phiba)
Membre
RE: Cannot change Z of modifier block or cylinder
Never mind. I found that I have to first select the object to which the modifier is attached, and then right-click and select the shape of the modifier. Before, I was just right-clicking in the dialog box without selecting the object. You may delete this post if appropriate - I do not see a way to do that myself.
Publié : 28/11/2024 3:08 am
