Can Layer Heights be set SPECIFICALLY for layers or groups without using the variable options?
I am trying to optimize my prints, and I print a lot of the same part over and over with only small changes.
Using variable layer heights it is hard to get exactly what I want, and has to be re-tweaked every time I load a new part.
Is there a way to just set 'layer 1-20 .2, and layer 21-25 .1'
I have messed around with the modifier boxes, but it doesn't seem to allow me to assign anything more than perimeters, infill, etc...
Hopefully I am just missing something.
Thanks for any help.
RE: Can Layer Heights be set SPECIFICALLY for layers or groups without using the variable options?
I did find this previous post/answer that helps with a screenshot.
So while inside variable layer height, you can set a modifier to set a specific height for a group of layers.
This is very helpful, but haven't quite figured out if you can set this multiple times...
Thought I would share what I have found in an older thread.
Just wanted to share that I did figure this out, and it is possible, but I am not positive in what version this became available.
I am currently using the PrusaSlicer 2.3.0-Alpha3 build, and they have added a '+' next to the modifier height range to add more than one grouping.
This is great, but might not be so easy to find for those looking (like I was).
The multiple layer height modifiers have been available since at least the 2.2 versions.
In fact its in the knowledge base manual https://help.prusa3d.com/en/article/modifiers_1767#height-range-modifier
