					                		Can filament settings be changed per object? - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/</link>
                <lastBuildDate>Wed, 10 Jun 2026 03:36:02 +0000</lastBuildDate>
                        <title>RE: Can filament settings be changed per object?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-768154</link>
                        <pubDate>Mon, 27 Oct 2025 20:37:14 +0000</pubDate>
                        <description><![CDATA[I&#039;ve thought about this, not only for printing different objects with different rigidity TPU Air, but having different TPU Air settings for different areas of the model for finer grained rig...]]></description>
                        <content:encoded><![CDATA[<p>I've thought about this, not only for printing different objects with different rigidity TPU Air, but having different TPU Air settings for different areas of the model for finer grained rigidity control in different parts of a model. I haven't actually been able to experiment (I don't have any frothing filaments yet), but based on my experience with "Manual MMU" printing for manually changing colors on a single color/filament printer, some of those learnings might be useful here.</p><p>I don't know how the filament change is done with the MMU (not having one). My first guess is it was in the tool change g-code, but looking at the Prusa MMU profiles I don't see anything in the tool change g-code. I wonder if it is triggered in the MMU with the T# gcodes. But, the XL tool change g-code is informative. As long as you don't have an MMU (or an XL, or other printer that can automagically change filaments/tools), you may be able to get away with manually changing a single color/tool printer profile to add tools for how many you want and then copy the tool change g-code from either the 2T or 5T Prusa provided XL printer profiles. Assign the different temperature TPU Air profiles to different (now virtual) filaments and assign/paint different extruders to where you want the different TPU Air temperatures.</p><p>There may be some iteration required to dial in the correct tool change g-code...</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-768154</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-767704</link>
                        <pubDate>Wed, 22 Oct 2025 23:53:18 +0000</pubDate>
                        <description><![CDATA[I dont think there&#039;s a way to do this with the slicer as is. I guess you could do an MMU print setup using different filament profiles for the different TPU settings and slice it. Then edit ...]]></description>
                        <content:encoded><![CDATA[<p>I dont think there's a way to do this with the slicer as is.</p><p> </p><p>I guess you could do an MMU print setup using different filament profiles for the different TPU settings and slice it. Then edit out all the filament swapping gcode.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>BaconFase</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-767704</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-765614</link>
                        <pubDate>Fri, 26 Sep 2025 16:31:47 +0000</pubDate>
                        <description><![CDATA[Thanks for the tip. I am using TPU Air by Siraya Tech. Shore hardness can range from 85 A to 65 A as temperatures range from 230C to 270C. One other filament setting that needs to be tweaked...]]></description>
                        <content:encoded><![CDATA[<ul><li>Thanks for the tip. I am using TPU Air by Siraya Tech. Shore hardness can range from 85 A to 65 A as temperatures range from 230C to 270C. One other filament setting that needs to be tweaked at is extrusion multiplier; the higher the temperature, the lower the flow rate needs to be, coming to as low as 55%. Any help is appreciated! 🙂</li></ul>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>Avinash</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-765614</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-765609</link>
                        <pubDate>Fri, 26 Sep 2025 16:03:48 +0000</pubDate>
                        <description><![CDATA[Alter the settings in the g code and insert M109 S (DEGREES C ) to whatever layer height What filament are you using, interested.]]></description>
                        <content:encoded><![CDATA[<p>Alter the settings in the g code and insert M109 S (DEGREES C ) to whatever layer height </p><p>What filament are you using, interested.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>John Lindo</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-765609</guid>
                        <title>Can filament settings be changed per object?</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-765590</link>
                        <pubDate>Fri, 26 Sep 2025 13:06:22 +0000</pubDate>
                        <description><![CDATA[I have a filament that gives different textures at different temperatures. Is there a way I can change nozzle temperature (and other filament settings) specifically per object and without ch...]]></description>
                        <content:encoded><![CDATA[<p>I have a filament that gives different textures at different temperatures. Is there a way I can change nozzle temperature (and other filament settings) specifically per object and without changing the extruder?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/can-filament-settings-be-changed-per-object/#post-765590</guid>
