					                		Bug at Slicer 2.9.0 - flat printing with different objects and colors - bug at Tools 1-3 - PrusaSlicer                                    </title>
                <link>https://forum.prusa3d.com/forum/prusaslicer/bug-at-slicer-2-9-0-flat-printing-with-different-objects-and-colors-bug-at-tools-1-3/</link>
                <lastBuildDate>Fri, 08 May 2026 14:17:27 +0000</lastBuildDate>
                        <title>RE: Bug at Slicer 2.9.0 - flat printing with different objects and colors - bug at Tools 1-3</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/bug-at-slicer-2-9-0-flat-printing-with-different-objects-and-colors-bug-at-tools-1-3/#post-736374</link>
                        <pubDate>Thu, 13 Feb 2025 16:19:37 +0000</pubDate>
                        <description><![CDATA[Posted by: @3d-print-brehm Workaround:The object must be separated and then reassembled, only then will all tools work and the slicer correctly recognize the individual objects.-------------...]]></description>
                        <content:encoded><![CDATA[<blockquote data-userid="545592" data-postid="736331" data-mention="3d-print-brehm"><div class="wpforo-post-quote-author"><strong>Posted by: @3d-print-brehm </strong></div><p>Workaround:</p><p>The object must be separated and then reassembled, only then will all tools work and the slicer correctly recognize the individual objects.</p><p>----------------------------</p><p>Problemumgehung:</p><p>Das Objekt muss getrennt und wieder zusammengefügt werden, erst dann funktionieren alle Tools und der Slicer erkennt die einzelnen Objekte richtig.</p></blockquote><p> </p><p>So support was right when they told you that the fault was on your side. The last solution is not an alternative but it is the only correct one.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>miroslav.h4</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/bug-at-slicer-2-9-0-flat-printing-with-different-objects-and-colors-bug-at-tools-1-3/#post-736374</guid>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/bug-at-slicer-2-9-0-flat-printing-with-different-objects-and-colors-bug-at-tools-1-3/#post-736331</link>
                        <pubDate>Thu, 13 Feb 2025 12:50:41 +0000</pubDate>
                        <description><![CDATA[Workaround:The object must be separated and then reassembled, only then will all tools work and the slicer correctly recognize the individual objects.----------------------------Problemumgeh...]]></description>
                        <content:encoded><![CDATA[<p>Workaround:</p><p>The object must be separated and then reassembled, only then will all tools work and the slicer correctly recognize the individual objects.</p><p>----------------------------</p><p>Problemumgehung:</p><p>Das Objekt muss getrennt und wieder zusammengefügt werden, erst dann funktionieren alle Tools und der Slicer erkennt die einzelnen Objekte richtig.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusaslicer/">PrusaSlicer</category>                        <dc:creator>3D-Print Brehm</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/bug-at-slicer-2-9-0-flat-printing-with-different-objects-and-colors-bug-at-tools-1-3/#post-736331</guid>
                        <title>Bug at Slicer 2.9.0 - flat printing with different objects and colors - bug at Tools 1-3</title>
                        <link>https://forum.prusa3d.com/forum/prusaslicer/bug-at-slicer-2-9-0-flat-printing-with-different-objects-and-colors-bug-at-tools-1-3/#post-736323</link>
                        <pubDate>Thu, 13 Feb 2025 12:25:50 +0000</pubDate>
                        <description><![CDATA[flat printing with different objects and colorsI have noticed that the Prusa Slicer is not working optimally here, because if I want to print from different tools, the slicer deletes the obj...]]></description>
                        <content:encoded><![CDATA[<p>flat printing with different objects and colors</p><p>I have noticed that the Prusa Slicer is not working optimally here, because if I want to print from different tools, the slicer deletes the objects.</p><p>Tools 1-3 are affected, as far as I could find out. Tools 4 and 5 are not affected.</p><p>Prusa has already been informed by email with examples.</p><p>Unfortunately, the support agent once again said that I was doing something wrong and that it wasn't the slicer's fault. ;o)</p><p>---------------------------</p><p>flächenebenes Drucken mit verschiedenen Objekten und Farben</p><p>Ich habe festgestellt dass der Prusa Slicer hier gerade suboptimal läuft, denn wenn ich aus verschiedenen Werkzeugen drucken möchte, löscht der Slicer die Objekte.</p><p>Betroffen ist das Werkzeug 1-3, so wie ich es heraus finden konnte.Werkzeuge 4 und 5 sind davon nicht betroffen.</p><p>Prusa wurde per Mail mit Beispiele schon per Mail informiert.</p><p>Leider mal wieder die Aussage vom Support Agent, ich würde etwas falsch machen und am Slicer liegt es nicht. ;o)</p><p><a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/e1afa691-screenshot-2025-02-13-080612.png"><img class="alignnone size-medium wp-image-174275" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/e1afa691-screenshot-2025-02-13-080612-600x500.png" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/d0f33e78-screenshot-2025-02-13-080655.png"><img class="alignnone size-medium wp-image-174274" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/d0f33e78-screenshot-2025-02-13-080655-600x500.png" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/03cae258-screenshot-2025-02-13-081327.png"><img class="alignnone size-medium wp-image-174273" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/03cae258-screenshot-2025-02-13-081327-600x500.png" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/ecab98eb-screenshot-2025-02-13-081732.png"><img class="alignnone size-full wp-image-174272" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/ecab98eb-screenshot-2025-02-13-081732.png" alt="" width="533" height="307" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/6499bf32-screenshot-2025-02-13-082556.png"><img class="alignnone size-medium wp-image-174271" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/6499bf32-screenshot-2025-02-13-082556-600x500.png" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/b26ad921-screenshot-2025-02-13-082654.png"><img class="alignnone size-medium wp-image-174270" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/b26ad921-screenshot-2025-02-13-082654-600x500.png" alt="" width="600" height="500" /></a> <a href="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/62c587e1-screenshot-2025-02-13-084202.png"><img class="alignnone size-medium wp-image-174269" src="https://storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/2025/02/62c587e1-screenshot-2025-02-13-084202-600x500.png" alt="" width="600" height="500" /></a></p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusaslicer/bug-at-slicer-2-9-0-flat-printing-with-different-objects-and-colors-bug-at-tools-1-3/#post-736323</guid>
