bridging issue in prusa slicer
Hello everyone,
I’ve noticed that PrusaSlicer (2.9.4) is creating overhangs instead of proper bridges in my prints. Is there a setting or parameter I can adjust to fix this issue?
Thanks in advance for your help!
Best Answer by Neophyl:
Without your project file from Prusa Slicer it is impossible to be sure, anything would be a guess. But I would guess you have the experimental setting 'Extra perimeters on Overhangs" set to enabled.
That is not normally enabled by default.
If you would like confirmation then please save your project from PS (File>Save Project As). Then take the .3mf file and ZIP it up. It must be zipped to attach it to a post here on the forum as the forum only allows a very limited number of file types.
RE: bridging issue in prusa slicer
