Arrange does a horrible job?
Cedar
(@cedar)
I have 4 objects on a print bed which easily fit (no rotating required) but the arrange button just can't seem to do it. Is the feature useless, or is there a bug? In the screenshot, you can see the result of clicking "arrange current bed". There is tons of room, and no problem to arrange manually.
Best Answer by Sembazuru:
You don't specify your PrusaSlicer version, so I'm assuming the latest (currently 2.9.2)...
If you right-click on the arrange button you should get a options drop-down. Check to make sure your spacing isn't too high. This is the spacing between objects. You may also want to play around with the "Geometry handling" options to see if one works better than the other.
Este debate ha sido modificado el hace 9 months por Cedar
Respondido : 11/06/2025 12:11 pm
Sembazuru
(@sembazuru)
RE: Arrange does a horrible job?
See my (limited) designs on:
Respondido : 11/06/2025 8:48 pm
2 les gusta
Cedar
(@cedar)
Thanks, perfect! I am using 2.92, and messing with those values worked. I needed 0.5 and "Accurate" and it worked!
Respondido : 12/06/2025 7:41 pm
2 les gusta
