Anchor part in part
Hello
So I have a part with a post protruding out of the part, and it's kind of a week point between the top surface of the part and the beginning of the post, even if i make a fillet around the post. So in solidworks I've unticked the merge part option so it's really two parts, the post is going down 2mm into the main part(se photo), but when I slice the part in Prusaslicer it dosent account for that, is there a way to slice this so the post go down into the main part(kind of like you make a hole for it and put it in). Also I would like to ask is there a way to make a section cut in the part after it's sliced, so you can see the internal slice geometric?
Terje
Postato : 30/05/2025 3:32 pm
