After slicing, the body disappears
RULA
 RULA
(@rula)
after slicing, the body and some parts of the interface disappear. I read that the system may not enough resources, but I have a MacBook pro Core i9, 32Gb RAM. There was a version 2.4, behaved the same way, I had to use a Super Slicer, with the release of 2.5 I installed it in the hope that this would fix the situation, but no. I deleted the program and installed it again, also without result. What could it be?
Video -> 006
Best Answer by Neophyl:
Thanks 🙂  However debugging wasn't that hard really.  Just a case of being a bit methodical.
After loading your project in I first changed the printer profile to one of mine then sliced.  The sliced preview wasn't there still so that meant it wasn't your Printer profile.  I checked the printer profile first as that was the most likely culprit, there is a no extrusion firmware type which I've seen people accidentally select before so that was the very first thing I checked lol.
So I put your printer profile back in the selection and then did the same with the filament profile, selecting one of my working ones.  After slicing the model preview was correct so that meant it had to be something in the filament settings.
Once you have it narrowed down to being a specific profile then there are a lot less things to look for.  Checking for zero's in fields is a common issue and once you start looking it becomes more obvious.
Anyway glad you have it all slicing now.
Publié : 05/07/2022 12:10 pm
jsw
 jsw
(@jsw)
RE: After slicing, the body disappears
It could be a corrupt .stl file.  If you will post the .stl (please remember to zip it, and I very much prefer .stl files over .3mf) I'll try slicing it and see what I get.
Publié : 05/07/2022 4:40 pm
RULA
 RULA
(@rula)
This happens with any stl, even if just draw a cube in Fusion 360 and export it.
Publié : 05/07/2022 9:23 pm
jsw
 jsw
(@jsw)
One thing I just noticed is that the view above has some kind of generic build plate instead of the commonly-displayed build plate of the specific Prusa model.  Do you have the correct Prusa model selected, as in the 'Printer:' drop-down?
Publié : 05/07/2022 10:22 pm
From Prusaslicer's File menu, save the project as a 3mf file. Compress it and attach it here. It contains the STL and all your settings so we can check it for issues.
Publié : 06/07/2022 12:49 am
RULA
 RULA
(@rula)
I have a Flying Bear Reborn printer.
Publié : 06/07/2022 7:35 am
RULA
 RULA
(@rula)
Cube_Clear.3mf
Publié : 06/07/2022 7:37 am
Your filaments extrusion multiplier is set to zero.  Change it to a reasonable value and the preview will show.  Its basically stopping any extrusion from happening.
Publié : 06/07/2022 7:52 am
RULA
 RULA
(@rula)
Thank you so much! I can't even guess where and why I could have done it, apparently something went wrong when importing the configuration snapshot. I admire your care and thoroughness! I would never have been able to find this problem myself. Problem solved!
Posted by: @neophyl
Publié : 06/07/2022 8:07 am
Publié : 06/07/2022 1:57 pm
