Adding Printers
Rufus
(@rufus)
Adding Printers
I have installed Prusa Slicer on a new computer and I see that the XL printer is no longer available to add as the 2T .6mm nozzle?? WHY? Is there any affects I might notice from this?? Can I transfer the slicer from another computer?
Opublikowany : 26/09/2025 8:38 pm
RE: Adding Printers
Ive just run the wizard again and Prusa seem to have standardised their naming formats.  It is in the wizard but its now called the Original Prusa Xl - 2T Input Shaper.  Nozzle sizes available are 0.25-0.8 in standard and 0.4-0.8 in high flow.  0.6 is available in there.
However if you scroll further down to the Legacy profiles section there is still an original Prusa XL- 2T with nozzles from 0.25-0.8mm.  That will be the non input shaping version and 0.6 is also available in that one to.
Make sure you have an up to date download of the configuration files (PS might need to access the internet to download them) before running the wizard.
Opublikowany : 26/09/2025 8:46 pm
Rufus
(@rufus)
Thanks for the info Neophyl. I have to be doing something wrong as I do not see that option and this is off of Prusa's web today? Even when I go back into my printers settings the menu still is missing it. I took a screen shot for you to see if I am missing something?
This post was modified 20 hours temu by Rufus
Opublikowany : 26/09/2025 10:17 pm
Rufus
(@rufus)
RE: Adding Printers
I finally figured this out. I am really sorry for my ignorance, but I got it now.
Opublikowany : 26/09/2025 11:28 pm
