Adaptive layer adjusting temperature ?
Olivier
(@olivier-8)
Hello,
I have a question: does the adaptive layer feature also adjust the temperature?
I’m using a Snapmaker A150, and I’ve noticed that when I change the layer height, I often have to manually adjust the temperature to get good results.
For example:
  • 0.10 mm → 192°C
  • 0.32 mm → 203°C
I’m currently using Cura and would like to know if it’s possible to automatically adjust the temperature based on the layer height.
Napsal : 09/04/2025 3:19 pm
