2.6.0 Error: Variable layer height is not supported with organic supports
Bob_CP
(@bob_cp)
Miembro
Error: Variable layer height is not supported with organic supports. That is the exact verbiage for the Error. I know there is a thread on this, but no mention of when this might be fixed.  It is a big deal!  Any idea when this will be available????  Organic supports also do not work with height range modifier for layer height changes, even above the supports
Respondido : 21/08/2023 4:23 pm
me gusta
VisualReversal
(@visualreversal)
RE: 2.6.0 Error: Variable layer height is not supported with organic supports
I don't know if you ever got the solution to this problem but I came across it today along with a solution. In my case I was slicing a file that I made for the MK4 with a .4 nozzle and 0.30 layer height and 0.30 printer settings. However when I tried to transfer to an input shaper profile with 0.20, I got the error. Then I realized that I still had the 0.30 layer height in the range height modifier. Once I switched it to 0.20 to match the profile, the problem went away. Hope that helps.
Respondido : 06/11/2023 4:14 am
namdosan1409
(@namdosan1409)
Miembro
first 0.4 then 0.2 layer height where organic support isn't further printed ... Variable layer height is not supported with Organic supports. car games
car games
Respondido : 08/11/2023 4:57 am
FLRaider
(@flraider)
Miembro
I get this error on ALL models with either Variable Layer Height tool or Height Range Modifier even when there are NO supports at all.
Respondido : 16/02/2024 5:12 pm
jonh david
(@jonh-david)
Miembro
Has anyone found a workaround? This is preventing me from printing detailed miniatures with tree supports. It's almost as scary as a malfunction in Fnaf' Freddy Fazbear! Any tips appreciated. Maybe tweaking the support settings manually?
Respondido : 24/03/2025 7:07 am
