2.5.0 Custom Printer Not Setting Temperatures
bbeardb
(@bbeardb)
In Slicer, nozzle set to 235, Bed to 110.
In Gcode M104 and M109 are set to S220.
M190 is set to S65.
Later on in the code I get an M140 of S60 and an M104 of S215.
What gives?
I'm new to this printer, a Creatbot D600 Pro, which everyone at works says sucks.  I'm wondering if we've had a hard time because of this.  Creatware (Createbots version of Prusa) has the same results.  Cura spits out correct M Temp codes.
I should note I've only been printing for 3-4 months for fun, I'm not an engineer, so I'm learning all this as I go.
; generated by PrusaSlicer 2.5.0+win64 on 2023-03-15 at 17:47:38 UTC
; external perimeters extrusion width = 0.45mm
; perimeters extrusion width = 0.45mm
; infill extrusion width = 0.45mm
; solid infill extrusion width = 0.45mm
; top infill extrusion width = 0.40mm
; first layer extrusion width = 0.42mm
M201 X9000 Y9000 Z500 E10000 ; sets maximum accelerations, mm/sec^2
M203 X500 Y500 Z12 E120 ; sets maximum feedrates, mm / sec
M204 P1500 R1500 T1500 ; sets acceleration (P, T) and retract acceleration (R), mm/sec^2
M205 X6.00 Y6.00 Z0.20 E2.50 ; sets the jerk limits, mm/sec
M205 S0 T0 ; sets the minimum extruding and travel feed rate, mm/sec
M107
M190 S65 ; set bed temperature and wait for it to be reached
M104 S220 ; set temperature
;TYPE:Custom
G28 ; home all axes
G29 ; auto bed leveling
G92 E0 ; reset extruder
G1 Z5 F5000 ; lift nozzle
M109 S220 ; set temperature and wait for it to be reached
G21 ; set units to millimeters
M82 ; use absolute distances for extrusion
G92 E0
; Filament gcode
M107
;LAYER_CHANGE
;Z:0.3
;HEIGHT:0.3
Later on...
;LAYER_CHANGE
;Z:0.5
;HEIGHT:0.2
G1 Z.5 F7800
M104 S215 ; set temperature
M140 S60 ; set bed temperature
G1 E1.45456 F1800
G92 E0
G1 X300.316 Y302.637 F7800
G1 E2 F1800
;WIDTH:0.449999
Posted : 15/03/2023 6:09 pm
RE: 2.5.0 Custom Printer Not Setting Temperatures
can you please save a project file, (File, saveProjectfile as,) and save the file as a .3mf file, then zip compress the project file, and post it on the forum, and we can have a look at it for you!
Posted : 15/03/2023 6:44 pm
anturov
(@anturov)
Posted : 15/03/2023 7:39 pm
bbeardb
(@bbeardb)
Incorrect Temp Spacer2
Here you go!
Posted : 16/03/2023 4:03 am
this printer seems to be set up as a dual extruder printer,
You appear to be using extruder 1 for this print.
In your original setup you chose the following filaments
they were set up with PLA Temperatures
which is why you were seeing the unexpected temperatures in the G Code
I have changed the filament designation for the selected filaments
Modified ABS Temps   (Revised Zip File containing revised .3mf file)
and now you should see the correct temperatures in your Gcode
Posted : 16/03/2023 5:55 am
bbeardb
(@bbeardb)
Ah, I see what I was doing.  Even though I was changing and saving the filament settings, I needed to go back to the plater and change it here:
Oops... Thank you!
Posted : 16/03/2023 3:50 pm
Sometimes we miss the obvious,
unfortunately, the initial post didn't really help, it was the post with the .3mf file that was the key.
Happy printing
Joan
Posted : 16/03/2023 5:18 pm
