How to print ASA safe in a not so good ventilated basement?
Página 2 / 2
UjinDesign
(@ujindesign)
RE: How to print ASA safe in a not so good ventilated basement?
Posted by: @danshady
If you are going to be actively moving air out of the chamber for ventilation purposes, you are going to need to replace it with heat.
Not necessarily, it depends. If you have a pretty well sealed printer, you're able to prevent air pollution leaking into the room by just creating a slight negative pressure in the chamber. In other words, only moving a little bit of air with your exhaust fan and thus only exhausting a little bit of hot air out of the chamber.
Posted by: @ruebarb
The advanced filtration is grossly insufficient for VOCs. The little bit of carbon they have in their, you will still have fumes passing right through. I ran a half spool of ABS CF Core, the carbon is shot. The 600hrs of runtime is a joke, the HEPA filter yes, VOC no, maybe 6 hrs and then maybe 70% effective when it was new.  Vent outside if you can. I'm tossing the rest of my ABS, I can't vent outside. Working on improving VOC filtering too.
I've never printed ABS. I have printed looooots of PLA, some PETG and occasional ASA. Total print hours for me has been around 1700 hours. I only now recently changed the air filter just for safety, but I'm not even sure it was needed to be honest. I've got an air quality monitor next to the printer at all times. Not only does the air filter work (if my expensive air quality monitor is to be believed), I am also very satisfied with the longevity of the filter when printing with aforementioned materials.
That said, PLA is several orders of magnitude cleaner than ABS according to tests, but I am a bit skeptical towards the carbon filter was depleted after a few hours of ABS. Keep in mind that most air quality measurers can't distinguish between different types of VOCs, and that they give out false flags frequently. For example, normal water vapor can trigger the air quality measurer. So if you're boiling spagetti in the kitchen whilst printing with ABS, you might think that you're dealing with ABS fumes when the VOCs measured is just detecting water vapor.
Respondido : 11/03/2026 11:34 am
Print_Fandango
(@print_fandango-2)
Miembro
Any leaked info as to whether PRUSA is going to be releasing an active chamber heater for the Core One. As much as I like the mods people are making, I would never trust my printer with one of those and that is limiting for my workflow....I am not interested in any mods that could potentially set my house on fire.
This is the only thing stopping me from selling my H2D and fully moving into the PRUSA ecosystem. Right now, the H2D is vastly superior in heat management. It can reach 65 degrees in less than 5 minutes, and automatically adjust this temp throughout a print job.
Esta publicación ha sido modificada el hace 2 months 2 veces por Print_Fandango
Respondido : 22/03/2026 10:43 pm
UjinDesign
(@ujindesign)
Posted by: @print_fandango-2
While I understand and partly support being skeptical towards mods, you shouldn't discredit all of them. A lot of mods made for Prusas (and 3D printers in general) are made by people who are engineers by trade.
Respondido : 23/03/2026 2:12 pm
The latest firmware: 6.5.3 has undocumented changes around chamber temperature management. If I were to speculate, perhaps... maybe... Prusa are preparing to introduce an actively heated chamber mod.
Respondido : 24/03/2026 7:14 pm
Print_Fandango
(@print_fandango-2)
Miembro
tht is very interesting,  Do you have any more details? or more contest as to what do you see in the FW ?
They need to increase the chamber temp so it can compete with the H2 platform. Adding the INDX is a great step but they are lacking a better AMS type integration, in the sense that the filament management needs to be simplified. I would also like to know is the temperature going to be managed now that the INDX version is going to be taller (lots of PTFE tubes poking up).
Lots to thing about, I really hope to see some good progress. The INDX is not enough at the moment.
Esta publicación ha sido modificada el hace 2 months por Print_Fandango
Respondido : 24/03/2026 7:18 pm
It's not as simple as increasing the chamber temp. The motors, electronics, lubricants, plastics all have to be able to handle the higher temps. The chamber also needs to be properly insulated as well.
Since the Core One L is not available in kit form, I'm wondering why Prusa decided against including an option for a actively heated chamber.
Respondido : 24/03/2026 7:21 pm
Print_Fandango
(@print_fandango-2)
Miembro
what do you see in the FW?
Respondido : 24/03/2026 7:22 pm
https://forum.prusa3d.com/forum/postid/787212/
Respondido : 24/03/2026 8:01 pm
Miembro
ASA in general smells low.  Polymaker ASA seems to have much less odor than other brands.  I have 4 printers in one room in the living area.  I do nto smell ASA at all.
Posted by: @simmania
I ordered a Prusa Core One L. I want to print large ASA objects. I therefore those the Core One L.
I need to place the printer in the basement. This space is not very good ventilated. There is one 120 mm opening to the outside world.
I want to print safe and take care of the toxic fumes. So I ordered the Core One L with the extra filter and fan.
But I do not think that is enough.
So I was thinking: what about connecting the output of that filter with a hose to this opening to the outside world so that all fumes are blown outside the basement?
Problem with that is that I will blow hot air to the outside world. Somewhere cold air will be sucked in. So the basement will cool down and I think the printer chamber temperature will drop too.
How to prevent this? I have a heat exchanger laying around. Could that help? Then I would need some input to the printer chamber to be able to blow the preheated air into the printer. But that will still be a relative low temperature. So you will get all kind of cold air flow inside the printer chamber. Not good.
Putting the whole printer inside a second chamber that is connected to the heat exchanger may be an option? But placing the whole printer inside a chamber that is significant warmer than standard environment temperatures may be not good for the printer. The electronics (and especially the power supply) is not designed for that. Resulting an fire danger.
So what  should I do? Any ideas?
Respondido : 25/03/2026 10:13 am
Cédric
(@cedric)
Posted by: @cwbullet
The sensitivity for the smell of ASA/ABS seems very varying among individuals, I cant stand ASA or ABS. The IKEA starkvid air cleaner with carbon filter seems to take care of it quite decently in the garage.
Respondido : 25/03/2026 11:47 am
Because you can't smell styrene doesn't make it any less dangerous. I keep my printer next to a window with an exhaust fan.
Respondido : 25/03/2026 1:36 pm
Página 2 / 2
