Print Bed Loose?
Shorty54
(@shorty54)
Print Bed Loose?
Can anyone verify if their print bed is loose?  If I place my hand in the middle of the heatbed, I can move the bed forward/backwards and left/right.
This seems odd to me, as my MK3S+ and MK4s do not do this.  I am getting the same layer shifting and lots of VFAs.  I have checked gantry, and done several calibration tests with the same results.
Posted : 15/01/2026 10:34 pm
Ruebarb
(@ruebarb)
RE: Print Bed Loose?
That is not right, mine is solid, rocks the entire printer. Start checking all the screws and attachment points.
Posted : 16/01/2026 3:25 pm
Shorty54
(@shorty54)
Under my heat bed there are 3 white threaded standoffs, kind of in a triangle, 2 in the front one in the back. They move when the bed moves. Do yours have fasteners in them?
Posted : 16/01/2026 3:39 pm
audry
(@audry)
I assembled my C1 in october, and recently I noticed a printed part with horizontal holes... strange....
Checking all the bed assembly, I discovered the front left bed screw assembly was litteraly floating, leaving the bed only on 2 screws.
I did follow the assembly advice not too tighten screw there, but I was probably too respectful of the mechanics.
Now, as a regular monthly maintenance check (once every 50 prints) I check all the screws from the bed to XYCore assembly, making sure one day my Nextruder won't fall on the bed while printing 🙂
Posted : 01/02/2026 7:57 am
mnentwig
(@mnentwig)
It may be a good idea to use light, hand-removable threadlock ("blue Loctite") on the metal-to-metal screws. It's not official recommendation, for whatever reasons (think possibility of royal screw-ups if it gets into bearings, over-achievers twisting heads off stainless screws...) but with vibrations and thermal cycling possibly quite obvious.
Posted : 01/02/2026 9:05 am
Shorty54
(@shorty54)
The Core One L has a completely different heat bed assembly. I have found no instructions or schematics on the assembly. Prusa has provided none either. They also claim the loose bed has no issues on the print quality.
Posted : 01/02/2026 5:17 pm
