NOISY Core One
Page 2 / 2
Keeganmagee22
(@keeganmagee22)
Noise
Noise
This post was modified 3 weeks ago by Keeganmagee22
Posted : 17/02/2026 12:26 am
mnentwig
(@mnentwig)
RE: NOISY Core One
 Have you tried stealth mode? If you prioritize noise, it's for you. Most people don't prioritize noise and don't use it.
Posted : 17/02/2026 9:37 am
Posted by: @ana-lissa
Hi all!! I can see this noisy-bed situation with the Prusa Core One is really frustrating, especially when you just want a smooth, quiet print. Often, the noise comes from vibration or uneven movement, so checking belts, bearings, and frame alignment can sometimes help reduce it. A few people have also mentioned that lubrication and making sure the bed screws aren’t too tight (or too loose) can make a surprising difference.
For anyone who also runs a 3D printing blog or support site, posting guides like this is really useful. But once you build your site, keeping it secure, updated, and easy to navigate is important too. That’s where reliable WordPress maintenance services help; they make sure your site stays fast, backed up, and running smoothly so readers can access your troubleshooting posts without issues.
Hope you find a good fix soon and get back to quiet printing
[hidden spam link removed]
For quiet printing, just lubricate your Core One or Core One L with a generous serving of spam.
Posted : 27/02/2026 8:39 pm
Zombatha
(@zombatha)
RE: NOISY Core One
Is there anyone who has tested to place anti vibration plates on the sides of Core One or Core One L ?
I find the vibration noise very loud from the metal sides of my printer and I was wondering if  the noise could be reduced
by fastening self adhesive bitumen plates on the inside of the printer. There is not much room in the Core One L though,
so it might not be possible.
Has any one tested this or somethis similar?
Posted : 04/03/2026 6:32 am
RE: NOISY Core One
Posted by: @zombatha
Have you tried damping the panels by touching them, and does it actually have a significant effect?
I think the consensus for the Core One is that it is preferred to damp the vibrations closer to the source. If the stepper motors excite resonances at certain speeds, try a new phase stepping calibration to see whether that makes the printer more quiet. If a panel rattles against the frame somewhere, try to re-seat the rivets in that area. If the noise stems from some other internal component that can rattle/vibrate, try to find and damp that.
Posted : 04/03/2026 8:50 am
alphasigma
(@alphasigma)
RE: NOISY Core One
...touching slightly the printhead and/or rails during movements also can help to identify the source of a noise (eg. no/too less lubrication, missalignment etc).
BUT, when searching for a source of a noise do this with - at least - removed top cover!!! The top cover - and also the side covers - can have a significant impact by redirecting the noise to an area from which it does not originate.
Core One L
Posted : 04/03/2026 10:52 am
Page 2 / 2
