Link lost #35331 (CORE One L)
Strona 2 / 2
Ruebarb
(@ruebarb)
Reported issue to Prusa CS last night, useless as usual. "WE are investigating this issue. Unfortunately, With complex printers, the issues can be complex too "
Downgraded to 6.5.2, Hard Rest to 6.5.2. Printer was off last night. Started cold printer this morning, successfully printed the 8 hr print. Doing another shorter print and then will do again the same 8hr print. I really hope this is a firmware issue for 6.5.3 and not a hardware issue.
Core One L MMU3, MK3S
Opublikowany : 25/04/2026 7:32 pm
alkaba
(@alkaba)
RE: Link lost #35331 (CORE One L)
I've had these Link lost faults also on 6.5.2...
Engineering filament freak
1x Prusa Mini (HT modded)
1x Modded MK3.5 "HT" (450C nozzle temp)
1x Modded Core One L (75C chamber temp, 450C nozzle)
1x Modded Core One + (70C chamber temp, 450C nozzle)
Opublikowany : 26/04/2026 6:57 am
Ruebarb
(@ruebarb)
Thanks, I completed 20hrs of prints without issue. So if you saw this issue on the 6.5.2. Then it appears to be an issue with the firmware in general, we can assume then, the hard reset did clear the issue for now.
Opublikowany : 26/04/2026 11:52 am
Strona 2 / 2
