Link lost #35331 (CORE One L)
Page 1 / 2
Ruebarb
(@ruebarb)
Just when you think you finally can't find any more bugs, Prusa never disappoints.
Crashed during a Print.
The support article is garbage. https://help.prusa3d.com/article/link-lost-35331-core-one-l_969549
Core One L MMU3, MK3S
Posted : 13/04/2026 11:40 pm
alkaba
(@alkaba)
RE: Link lost #35331 (CORE One L)
I have the same problem... Happened twice on the same (very expensive) 12h PA12-CF print. At the same point (around 190mm Z-axis). Support told me, that it happens on some printers and the dont know the cause. They said, they will send me a replacement unit. Sad story, but i hope they will solve it.
Engineering filament freak
1x Prusa Mini (HT modded)
1x Modded MK3.5 "HT" (450C nozzle temp)
1x Modded Core One L (75C chamber temp, 450C nozzle)
1x Modded Core One + (70C chamber temp, 450C nozzle)
Posted : 17/04/2026 3:05 pm
Ruebarb
(@ruebarb)
By unit, what exactly are they replacing?
Posted : 17/04/2026 3:07 pm
alkaba
(@alkaba)
The whole printer... I suspect some hardware fault with the AC boards. I love the printer and the print quality, but this is just sad. I cannot rely on it.
Posted : 17/04/2026 3:09 pm
Ruebarb
(@ruebarb)
This is unbelievable, they can't diagnose their printers, they can't fix their printers. This only happened once and did not repeat so far.
Posted : 17/04/2026 5:41 pm
_KaszpiR_
(@_kaszpir_)
I believe they can't telepathically probe the electronics in the board to see which component is a culprit. That's why they send a replacement - the user gets a new device while they will take the device under special diagnose in the local lab.
For nme it seems like it is not a one off use case, but some batch of devices is affected and they are aware of it already.
Maybe it starts from time to time and gets more frequent?
Posted : 17/04/2026 8:09 pm
alkaba
(@alkaba)
Well my printer did it twice on the same model (different g-code) in nearly exactly the same z-height. Also the printer smells inside like burned acrylic. I think also its a bad batch.
Posted : 17/04/2026 8:11 pm
Ruebarb
(@ruebarb)
That is what replacement parts are for. You replace the defective part and send it back, not the entire printer. Diagnostics vs Failure Analysis are different.
Posted : 17/04/2026 8:17 pm
Ruebarb
(@ruebarb)
For all we know this is a firmware issue.
CS already tried to get me to replace the load cell because it was losing the Z reference and the nozzle would crash into the bed before the nozzle cleaning, many others had the same issue.  This is a firmware bug, we finally got the start G code reference on github to be accepted until they figure it out. They finally made the update to the last C1L config update, Removing the Q until they figure out the firmware problem.
G28 ;home all without mesh bed level, Removed Q
Posted : 17/04/2026 8:27 pm
Ruebarb
(@ruebarb)
Did you power off and on the printer, not just a reset between the events?
Posted by: @alkaba
Posted : 17/04/2026 8:31 pm
alkaba
(@alkaba)
Yes, tried everything.
Posted : 17/04/2026 8:51 pm
Ruebarb
(@ruebarb)
Sorry you are dealing with this. Please let us know how it all goes.
Noticed your signature, 75C chamber temp. How hot have you gone?
Posted : 17/04/2026 9:10 pm
alkaba
(@alkaba)
Posted by: @ruebarb
75 C just for a little while. Sadly i had the "Link lost" error even with the stock FW at 60c Chamber temps... Will let you know. Hopefully they will ship a new printer ASAP, because i waited 2+ months for this one.
Posted : 17/04/2026 9:16 pm
_KaszpiR_
(@_kaszpir_)
hm I remember setting G28 without Q really the same day when I got the printer, some weird things were happening with the quick home and I REALLY did not like the fact the bed gets down on filament change), but since setting it I have absolutely no issues with the printer with any red screens.
Posted by: @ruebarb
Posted : 18/04/2026 12:25 am
Ruebarb
(@ruebarb)
Crash-o-matic at it again, appears to happen after printer has been on/printing for long period of time 20+hrs, atleast that is all I can correlate with 2 failures.
Posted : 24/04/2026 8:26 pm
alkaba
(@alkaba)
Posted by: @ruebarb
That really sucks... The worst is, that it happens on these long prints. Mine was about 12hrs, yours 20+. My print always failed around 90-95% which sucks even more. And it was from a really expensive material... My printer is ready to ship Back to prusa and i am waiting for the parcel company for pickup.
Ironically... My frankenstein core1 built from scrap and mk3.5 parts is printing everyday without any failure...
Did you contact the prusa support?
Posted : 24/04/2026 9:00 pm
Ruebarb
(@ruebarb)
You already received the replacement C1L?  I tried CS, but appears the indx release must have them busy. I sent an email, but will be contacting them by chat when the wait is short.
Posted : 24/04/2026 9:53 pm
alkaba
(@alkaba)
Not yet, still waiting for them to pick up the faulty printer.
Posted : 24/04/2026 10:03 pm
Ruebarb
(@ruebarb)
Supposedly the C1L are delayed for weeks due to a nozzle issue. I wouldnt surrender the printer until I get the replacement.
Posted : 24/04/2026 10:38 pm
Ruebarb
(@ruebarb)
Just happened again, no good correlation
Posted : 25/04/2026 12:48 am
Page 1 / 2
