Heatbed wobbles
How much give should the heatbed have ?
After a lot of issues i noticed by accident that i coud press the heatbed down at the back. Removing the print plate i could see that the 3 mounting screws had a lot of give. after tightening them for a test i noticed that the bed would still have some give (there is a little spring to it).
If this is not intended (or at least not to the wobbly screw) it could explain why we had so many issues withe the C1L so far.
Publié : 27/03/2026 9:46 am
All the screws on the C1L should be check, every single screw on my enclosure was not tightened.
Core One L MMU3, MK3S
Publié : 31/03/2026 1:20 pm
