Firmware Bug: Random Print Pause, Time Loss
Ruebarb
(@ruebarb)
The print randomly pauses and then continues. The print continually loses time during the print, not just the pauses. Sent this all to CS
Video
https://drive.google.com/file/d/1tr0_4jlXSuRr25PzPc6kYNY7PdaA89wF/view?usp=sharing
Core One L MMU3, MK3S
Postato : 19/02/2026 5:15 pm
_KaszpiR_
(@_kaszpir_)
RE: Firmware Bug: Random Print Pause, Time Loss
File uploaded via PrusaConnect or PrusaLink directly to the usb?
Postato : 21/02/2026 9:44 am
Ruebarb
(@ruebarb)
PrusaLink to USB
Posted by: @_kaszpir_
Postato : 21/02/2026 1:17 pm
_KaszpiR_
(@_kaszpir_)
Does it happen if you reslice it without G2 Arc Fitting ?
Can you share the currently used gcode?
Another idea - replace pendrive?
Postato : 21/02/2026 1:56 pm
Ruebarb
(@ruebarb)
Haven't tried it without the G2 Arc Fitting. 36hr print, not repeating it, it did finish, with some defects from the pause, but for it's purpuse they aren't noticable. This pause happened many times.
I'm not using the Prusa USB, Higher speed samsung USB, uploading via Prusalink is quicker with it.
Hasn't happened on any other prints yet.
https://drive.google.com/file/d/1NAFY01oFgMsukolYOv-qVsAoFFoYzmcG/view?usp=sharing
Postato : 21/02/2026 4:40 pm
I can hear the nextruder gears clicking. Maybe jam detection is causing this. Are you printing PLA? I doubt this is a firmware bug. If you still believe it is then you need to open an issue on github: https://github.com/prusa3d/Prusa-Firmware-Buddy/issues
Postato : 21/02/2026 5:31 pm
Ruebarb
(@ruebarb)
The clicking is the sound of my keyboard with Prusa CS. This is PLA.
Postato : 21/02/2026 5:37 pm
Posted by: @ruebarb
Ah OK. LOL. Anyway, I think it's a filament jam causing this. I don't print a lot of PLA anymore (especially on a Core One). Try turning off filament jam detection.
Postato : 21/02/2026 5:53 pm
Ruebarb
(@ruebarb)
There was no clicking like a jam would indicate, no errors detected, why would the printer pause. Typically is just keeps on going with a jam. How does it unjam itself over and over again without extruding. It just pauses, waits, then continues. CS was thinking it was acting like a power loss, no power issues were occuring. To me seems like it was waiting for data to be transmittted, also the ETA of the print kept lossing time continously, even when it was printing, not just the pauses, the preview of the model screen was also blank. The ETA times on the main screen and preview screen also didn't match. Seems alot more logic then mechanical.
Postato : 21/02/2026 5:58 pm
Posted by: @ruebarb
The binary g-code would be on the USB. Yes is gets streamed to the firmware. Perhaps the USB key has a problem? Have you tried swapping it out? This is what I use in mine: https://www.sandisk.com/products/memory-cards/microsd-cards/industrial-microsd?sku=SDSDQAF3-008G-I
Postato : 21/02/2026 6:02 pm
Ruebarb
(@ruebarb)
I've been running SAMSUNG FIT Plus 3.1 USB Flash Drive, 128GB, 400MB/s, formatted for FAT. Flusher fit and much faster than the Prusa USB.
Postato : 21/02/2026 6:23 pm
Ruebarb
(@ruebarb)
I'll give the scan disk a try, simpler to deal with FAT on smaller storage anyway.
Postato : 21/02/2026 6:32 pm
Posted by: @ruebarb
I have two of these SanDisk Industrial MLC MicroSD one in the buddy cam and one for printer. The printer uses a very low profile USB adapter  But then maybe Prusa should get away from 15 year old tech (the Buddy Board) STM32F407VGT6 and something a bit more modern with built-in eMMU
Postato : 21/02/2026 7:51 pm
1 persone hanno apprezzato
mctaggart
(@mctaggart)
Utenti
I used this same drive and ran into the same exact problem/phenomenon. Switching to a usb 2.0 drive removed the problem entirely for me. I don't know why but these printers don't seem to either like usb 3.1 or samsung drives.
Posted by: @ruebarb
Postato : 05/04/2026 1:01 am
Ruebarb
(@ruebarb)
Thanks, glad to know it wasn't jsut me. Been using the drive & SD card Hyiger mention, no issues
Posted by: @mctaggart
Posted by: @ruebarb
Postato : 06/04/2026 12:07 pm
vhubbard
(@vhubbard)
Verbatum usb 3.0 drive gave me fits also.  Primarily failing to load correctly from Prusaconnect or directly from PrusaSlicer.   While some state a 3.0 USB will work, the firmware in the buddy boards is for 2.0 usb drives.  I went to a good quality 16 Gig drive USB2.0 and have had no problems since.
Posted by: @ruebarb
Posted by: @ruebarb
Postato : 06/04/2026 3:33 pm
