					                		Hardened steel nozzle - dummy move - General discussion, announcements and releases                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/</link>
                <lastBuildDate>Wed, 13 May 2026 13:30:49 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/#post-773054</link>
                        <pubDate>Fri, 05 Dec 2025 20:49:23 +0000</pubDate>
                        <description><![CDATA[I run &quot;only&quot; hi-temp ASA but this seems a conceptual gap in the whole Core One concept: That the single nozzle is used with incompatible materials, left in an unknown state and the residual ...]]></description>
                        <content:encoded><![CDATA[<p>I run "only" hi-temp ASA but this seems a conceptual gap in the whole Core One concept: That the single nozzle is used with incompatible materials, left in an unknown state and the residual contents will just get purged out. It is not that simple.</p>
<p>Only, when it's not, an interface that pretends it <em>is</em> doesn't really help... I use the "controls" menu a lot cramming in PLA for cold pull near the boiling point via extruder axis, cool down gradually feeding material, then pull out at 100 °C while heating back again (otherwise it would get stuck and tear). And this works, e.g. I clearly see the channels of a HF-nozzle in the cold pull plus the debris on repeat attempts, getting less and less. </p>
<p>Slightly OT, but neither firmware nor glossy color brochures guide the user in a direction that would even acknowledge this problem exists.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>mnentwig</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/#post-773054</guid>
                        <title>RE: Hardened steel nozzle - dummy move</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/#post-773021</link>
                        <pubDate>Fri, 05 Dec 2025 16:30:38 +0000</pubDate>
                        <description><![CDATA[Yeah, mine was nylon carbon fiber…]]></description>
                        <content:encoded><![CDATA[<p>Yeah, mine was nylon carbon fiber…</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>mbiasotti</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/#post-773021</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/#post-772988</link>
                        <pubDate>Fri, 05 Dec 2025 13:09:15 +0000</pubDate>
                        <description><![CDATA[Same happened to me. Now I run a few passes of cleaning filament through mine after a using high temp filament.]]></description>
                        <content:encoded><![CDATA[<p>Same happened to me. Now I run a few passes of cleaning filament through mine after a using high temp filament. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/">General discussion, announcements and releases</category>                        <dc:creator>hyiger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/#post-772988</guid>
                        <title>Hardened steel nozzle - dummy move</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/#post-772802</link>
                        <pubDate>Thu, 04 Dec 2025 02:37:01 +0000</pubDate>
                        <description><![CDATA[Don’t be a dummy like me when trying to unclog your nozzle: I removed it and use a butane torch to head the end - it blew the nozzle off the body (probably due to the expansion of the differ...]]></description>
                        <content:encoded><![CDATA[<p>Don’t be a dummy like me when trying to unclog your nozzle: I removed it and use a butane torch to head the end - it blew the nozzle off the body (probably due to the expansion of the differing metals). There goes $55 bucks!<br />next time I’ll let the Nextruder heat it while I clean it…</p>
<div id="wpfa-182190" class="wpforo-attached-file"><a class="wpforo-default-attachment" href="//storage.googleapis.com/prusa3d-content-prod-14e8-wordpress-forum-prod/wpforo/default_attachments/1764815821-7f64aaab-img_9107.jpeg" target="_blank" title="7f64aaab-img_9107.jpeg"><i class="fas fa-paperclip"></i>&nbsp;7f64aaab-img_9107.jpeg</a></div>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-l-general-discussion-announcements-and-releases/hardened-steel-nozzle-dummy-move/#post-772802</guid>
