RE: CORE One L Kit interest
edit window expired - strike out that part
If the PSU doesn't reliably shut down on overcurrent.
to make more sense 🙂
A lot of speculation but at the end-of-the-day, Prusa are still on record that they will not provide kits for the Core One L in the foreseeable future. I'm sure the Core One and it's future iterations will still be in kit form for now if you want to build something. My personal feeling is Prusa is evolving away from kits based on (speculation) that they probably were overwhelmed by support for the Core One.
My build was pretty uneventful but this was by far not my first complicated kit so I'm usually good at following instructions precisely. Would be interesting to know how many kits were partially built and returned versus the MK4.
It was also my conclusion after the C1 kit, that I dont think prusa will do this anymore. Just to much work, very complex costly packaging, extra detailed instructions, probably more support due to clumsy people and they sell it for quite a bit less money. I loved building my C1, If the kit and complete printer were the same price I would still chose the kit, its both fun , i know exactly how its built, and I can take my time to do everything perfect.
Just kind of eyeballing the support requests on this forum, I would guess the majority of issues were around belt routing: installing the motor pulley incorrectly, the gantry brackets in the wrong location etc. Or in one case, the user assuming the "belt was too short" and ordered a longer one to "fix" it causing even more problems. I might get Claude to chomp through the forum (when it's early morning in Europe) and summarize all of the support issues reported here. Would be a fun exercise.
Just to confirm again. Prusa is on record during a live stream as stating (I'm paraphrasing): due to regulatory certification issues (the AC bed), there will be no Core One L kits.
Which again, raises the question about repairs? If you cannot build the printer, does that mean you cannot repair the printer, and Prusa won't be selling spare parts? A deal killer for me. Does that mean all those people that want the INDX heads, need to have Prusa make the mod since they may have to work with the bed?
You can buy a replacement bed since it plugs into the power-supply. However you will not be able to buy the L as a kit. Also, the Core One will not have an AC bed upgrade for similar reasons as stated above.
