Rough outer wall, only on the side facing printer door
Evan Steinfedt
(@evan-steinfedt)
Hello,
I've been printing a lot of these pieces on our Core One printer and have consistently seen a rough strip along the edges of each one. This is fine, as these edges are not critical (but any help here would be appreciated). The real problem is the rough patch seen on the top quarter of this part. It seems that something abruptly changed because the first 75% of the part looks normal. The strange part is that I only see this rough wall issue on the faces that visible in the picture, which were oriented toward the printer door on the print bed. Every other surface looks fine.
Napsal : 12/06/2026 5:58 pm
