					                		Question about cleaning filament - How do I print this? (Printing help)                                    </title>
                <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/</link>
                <lastBuildDate>Thu, 11 Jun 2026 19:44:50 +0000</lastBuildDate>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/#post-764295</link>
                        <pubDate>Sat, 13 Sep 2025 20:42:39 +0000</pubDate>
                        <description><![CDATA[I don&#039;t usually use it when switching between PLA and PETG but I found it useful when switching from a high temperature filament such as PcCf to lower temp filaments.]]></description>
                        <content:encoded><![CDATA[<p>I don't usually use it when switching between PLA and PETG but I found it useful when switching from a high temperature filament such as PcCf to lower temp filaments. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>FoxRun3D</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/#post-764295</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/#post-764286</link>
                        <pubDate>Sat, 13 Sep 2025 19:02:28 +0000</pubDate>
                        <description><![CDATA[I hope I don&#039;t have to remove the tube... I am not fond of the quick connect insert pegs... I had a hell of a time getting them on once already. I suppose I should look at modifying that......]]></description>
                        <content:encoded><![CDATA[<p>I hope I don't have to remove the tube... I am not fond of the quick connect insert pegs... I had a hell of a time getting them on once already. I suppose I should look at modifying that...</p>
<p>They are 5M samples, so I should have no issues for a good while.</p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>shrap</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/#post-764286</guid>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/#post-764266</link>
                        <pubDate>Sat, 13 Sep 2025 15:11:35 +0000</pubDate>
                        <description><![CDATA[Posted by: @shrap-2 
I got a roll of filament that came with a small sample roll of cleaning filament. I have never used that before. Is it good with a Core One or in general? Or should I a...]]></description>
<blockquote data-userid="586963" data-postid="764260" data-mention="shrap-2">
<div class="wpforo-post-quote-author"><strong> Posted by: @shrap-2 </strong></div>
<p>I got a roll of filament that came with a small sample roll of cleaning filament. I have never used that before. Is it good with a Core One or in general? Or should I avoid it?</p>
<p>I have noticed issues when switching between PLA and PETG, so maybe it's a good thing to try?</p>
<p>I've used cleaning filament before on my MK4S. You basically setup the nozzle temp to whatever is specified and run it through the nozzle. One way would be to set it up as a custom filament in the Filament section, do a few purges and then unload it. Alternatively can do a cold pull. Prusa recently added a cold pull wizard to the 6.5.0-alpha firmware. I've been running that for a few days now (the firmware) and seems pretty stable. </p>
<p>What I'm not sure about is whether or not you need to remove the Bowden tube first and feed it directly into the extruder. I suppose that depends on how much you have. </p>]]></content:encoded>
                        <category domain="https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/">How do I print this? (Printing help)</category>                        <dc:creator>hyiger</dc:creator>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/#post-764266</guid>
                        <title>Question about cleaning filament</title>
                        <link>https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/#post-764260</link>
                        <pubDate>Sat, 13 Sep 2025 14:37:31 +0000</pubDate>
                        <description><![CDATA[I got a roll of filament that came with a small sample roll of cleaning filament. I have never used that before. Is it good with a Core One or in general? Or should I avoid it?
I have notic...]]></description>
                        <content:encoded><![CDATA[<p>I got a roll of filament that came with a small sample roll of cleaning filament. I have never used that before. Is it good with a Core One or in general? Or should I avoid it?</p>
<p>I have noticed issues when switching between PLA and PETG, so maybe it's a good thing to try?</p>]]></content:encoded>
                        <guid isPermaLink="true">https://forum.prusa3d.com/forum/prusa-core-one-how-do-i-print-this-printing-help/question-about-cleaning-filament/#post-764260</guid>
